Spoiler: Beschreibung You are part of a special defensive program of controlling the development of combat artificial intelligence. To eliminate emergencies, the front of nuclear installations were created around the planet. Specially trained personnel were put to hibernation sleep so that at a crucial moment, the protection mechanism could be activated. Boiling Steel - it’s a story oriented dynamic hardcore VR shooter with procedural generation locations and craftings in the futuristic world of mankind extinction. Survive You “waked up” alone and all humans disappeared. No one got in touch with you and there is no possibility to get out of the shelter. Life support systems are damaged, the final countdown begins. You have not much time to fix the situation. Find resources as soon as possible and restore your base. Explore Various biomes of the planet: black sands of the desert, scientific stations frozen in the ice, deep underground mines and cities in the clouds. Visit all locations in search for your answers. Hack Central terminal will help you connect to the available robots that remained on the planet. Scan zones in search of suitable machines. Take them under your control for resource extraction and defensive systems bypass. Every action you take is worth the energy, don't make mistakes. Fight Defeat your enemies. Use wisely the specifics of each robot under your control, improve its systems. Each of them is unique and differs in equipment and skills. Turn its cons into your pluses. Make decisions From your actions will depend on the outcome. Avenge, die or re-create. All in your hands. Das Spiel erscheint erst im 4.Quartal. Ich durfte jetzt vorab mal eine Pre Alpha Version Testen: https://youtu.be/1cKDZjOoSUY SolKutTeR: Beitrag verschoben
Hier mal die relevante Steam-Shop Verlinkung und Homepage, plus Ankündigung für weitere Plattformen wie z.B. PSVR. Wer sich darüber hinaus für die derzeitige Alpha interessiert, sollte im entsprechenden Discord-Channel einmal vorbeischauen. Boiling Steel von Mirowin
Ich hab es gestern auch 2 Std. gespielt,und ich will mehr davon Das Spiel könnte wirklich richtig gut werden,die Steuerung mit den Index Controller funktioniert auch sehr gut.
Boiling Steel erscheint heute bei Steam als EA und ich muss sagen, es ist richtig gut geworden. Gesendet von meinem SM-G975F mit Tapatalk
