Hallo, ich habe mein Dk2 nach Anleitung Installiert und auch ein Firmware Update durchgeführt. Die Kamera schaltet sich blos nicht ein, kein blaues Licht oder ähnliches an der Kamera zu sehen. Die Oculus an sich, hat ein Orangenes Licht leuchten. Ich habe auch swchon verschiedene USB Ports aus probiert 2.0 sowie auch 3.0 Ports, die Kamera geht nicht an. Diagnostic Log: { "Time": "2015-04-06_15:12:57", "SDK Version": "0.5.0.1", "Service Protocol": { "Major": 1, "Minor": 3, "Patch": 0 }, "RemoteProtocolVersion": { "Major": 1, "Minor": 3, "Patch": 0 }, "Service Running Time": { "Hours": 0, "Minutes": 28, "Seconds": 50 }, "System Specifications": { "Operating System": "Microsoft Windows 7 Ultimate ", "Processor": "Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz", "Graphics Adapters": [{ "Name": "NVIDIA GeForce GTX TITAN Black", "Video Controller RAM (MB)": 4095, "Driver Version": "9.18.13.4788", "Video Mode": "1920 x 1080 x 4294967296 Farben" }], "Total RAM (GB)": 16, "USB Tree": [{ "name": "Intel(R) 9 Series Chipset Family USB Enhanced Host Controller - 8CA6", "deviceid": "PCI\\VEN_8086&DEV_8CA6&SUBSYS_79171462&REV_00\\3&11583659&1&E8", "caption": "Intel(R) 9 Series Chipset Family USB Enhanced Host Controller - 8CA6", "manufacturer": "(Standard-USB-Hostcontroller)", "Devices": [{ "manufacturer": "(Standard-USB-Hostcontroller)", "name": "USB-Root-Hub" }, { "manufacturer": "(Generic USB Hub)", "name": "Generic USB Hub" }] }, { "name": "Intel(R) 9 Series Chipset Family USB Enhanced Host Controller - 8CAD", "deviceid": "PCI\\VEN_8086&DEV_8CAD&SUBSYS_79171462&REV_00\\3&11583659&1&D0", "caption": "Intel(R) 9 Series Chipset Family USB Enhanced Host Controller - 8CAD", "manufacturer": "(Standard-USB-Hostcontroller)", "Devices": [{ "manufacturer": "(Standard-USB-Hostcontroller)", "name": "USB-Root-Hub" }, { "manufacturer": "(Generic USB Hub)", "name": "Generic USB Hub" }] }, { "name": "Intel(R) USB 3.0 eXtensible-Hostcontroller", "deviceid": "PCI\\VEN_8086&DEV_8CB1&SUBSYS_79171462&REV_00\\3&11583659&1&A0", "caption": "Intel(R) USB 3.0 eXtensible-Hostcontroller", "manufacturer": "Intel(R) Corporation", "Devices": [{ "manufacturer": "Intel(R) Corporation", "name": "Intel(R) USB 3.0-Root-Hub" }, { "manufacturer": "Prolific", "name": "Prolific USB-to-Serial Comm Port (COM4)" }, { "manufacturer": "(Standard-USB-Hostcontroller)", "name": "USB-Verbundger�t" }, { "manufacturer": "(Standardsystemger�te)", "name": "USB-Eingabeger�t" }, { "manufacturer": "(Standardtastaturen)", "name": "HID-Tastatur" }, { "manufacturer": "(Standardsystemger�te)", "name": "USB-Eingabeger�t" }, { "manufacturer": "Microsoft", "name": "HID-konforme Maus" }, { "manufacturer": "(Standardsystemger�te)", "name": "HID-konformes Ger�t" }, { "manufacturer": "Microsoft", "name": "HID-konformes Benutzersteuerger�t" }, { "manufacturer": "(Standardsystemger�te)", "name": "HID-konformes Ger�t" }, { "manufacturer": "(Standardsystemger�te)", "name": "HID-konformes Ger�t" }, { "manufacturer": "(Standardsystemger�te)", "name": "USB-Eingabeger�t" }, { "manufacturer": "(Standardsystemger�te)", "name": "HID-konformes Ger�t" }, { "manufacturer": "(Standard-USB-Hostcontroller)", "name": "USB-Verbundger�t" }, { "manufacturer": "(Standardsystemger�te)", "name": "USB-Eingabeger�t" }, { "manufacturer": "(Standardtastaturen)", "name": "HID-Tastatur" }, { "manufacturer": "(Standardsystemger�te)", "name": "USB-Eingabeger�t" }, { "manufacturer": "(Standardsystemger�te)", "name": "HID-konformes Ger�t" }, { "manufacturer": "Microsoft", "name": "HID-konformes Benutzersteuerger�t" }, { "manufacturer": "(Standardtastaturen)", "name": "HID-Tastatur" }, { "manufacturer": "(Standardtastaturen)", "name": "HID-Tastatur" }, { "manufacturer": "(Standard-USB-Hostcontroller)", "name": "USB-Verbundger�t" }, { "manufacturer": "Oculus VR", "name": "Oculus Video Camera" }, { "manufacturer": "Intel(R) Corporation", "name": "USB 2.0-Hub" }, { "manufacturer": "(Standardsystemger�te)", "name": "USB-Eingabeger�t" }, { "manufacturer": "(Standardsystemger�te)", "name": "HID-konformes Ger�t" }] }] }, "Drivers": [{ "Path": "\\system32\\OVRDisplay64.dll", "Version": "1.2.4.0" }, { "Path": "\\system32\\OVRDisplayRT64.dll", "Version": "1.2.4.0" }, { "Path": "\\syswow64\\OVRDisplay32.dll", "Version": "1.2.4.0" }, { "Path": "\\syswow64\\OVRDisplayRT32.dll", "Version": "1.2.4.0" }, { "Path": "\\system32\\drivers\\RiftEnabler.sys", "Version": "1.2.4.0" }, { "Path": "\\system32\\OVRDisplay32.dll", "Version": "1.2.4.0" }, { "Path": "\\system32\\OVRDisplayRT32.dll", "Version": "1.2.4.0" }, { "Path": "\\system32\\drivers\\OCUSBVID.sys", "Version": "1.0.9.0" }], "Video Device Tree": [{ "Name": "NVIDIA GeForce GTX TITAN Black", "VRAM (MB)": 3072, "Monitors": [{ "Name": "\\\\.\\DISPLAY6", "Width": 1920, "Height": 1080, "Refresh Rate": 60 }] }], "Devices": [] }
Hast du mal das DK2 Netzteil angeschlossen und die Verkabelung noch mal überprüft? Manche vergessen gerne mal das Sync Kabel an die Kamera anzuschließen. Die Kamera leuchtet auch nur blau, wenn man eine VR Anwendung startet bzw. das Oculus Config Tool öffnet. Zeigt er denn im Config Tool die "Camera Serial:" an? Wenn ja wird sie zumindest erkannt. Wenn es dumm läuft kann es auch sein, dass du die Grafikkarten Treiber deinstallieren, mit DDU die Grafiktreiber Reste aus dem System (im abgesicherten Modus) komplett entfernen und dann noch mal die Grafiktreiber neu installieren musst. Hat bei Vielen auch geholfen solche Probleme zu beseitigen. Wenn alles nichts hilft: Oculus Support, die sind sehr hilfsbereit. Allerdings nur wenn du sie bei ihnen direkt und nicht z.B. über eBay gekauft hast... Edit: gerade noch was gefunden, hatte zufällig noch nen Thread im Oculus Forum auf und direkt der Link zu dem was im Topic steht: http://www.reddit.com/r/oculus/comments/31j71e/dk2_wont_go_into_extended_mode/ Ist es vielleicht das? Wenn nicht könnte es wohl scheinbar auch ein Problem mit dem HDMI Kabel sein.
Oke, es Funktioniert über den VGA stecker... Vlt ist mein HDMI Anschluss am rechner kaputt Ich habe die oculus dk2 seit Anfang an und es hat bis jetzt immer Funktioniert vlt beim nächsten Update wieder Danke für die Hilfe
