Sdk + Runtime 0.8.0.0
Dieses Thema im Forum "VR Entwicklung" wurde erstellt von Hammerschaedel, 22. Oktober 2015.
  1. Die Runtime ist unter
    https://developer.oculus.com/downloads/pc/0.8.0.0-beta/Oculus_Runtime_for_Windows/
    zum Downloaden
    Changelog
    Oculus PC SDK 0.8.0.0 Beta
    The Oculus SDK 0.8 release changes SDK from an HMD-based model to a session-based model and adds several new features.
    New Features
    The following are new features for the Oculus SDK and runtime:
    Improved support for Windows 10.
    Added ovr_GetSessionStatus, which returns whether the headset is present and whether it has VR focus and can render to the headset.
    Added ovr_Detect to OVR_CAPI_Util.h , which enables you to detect the presence of a headset without initializing LibOVR. This can be useful when a game has VR and non-VR modes.
    Added HandStatusFlags to ovrTrackingState, which specifies whether the the Oculus Touch controllers are being tracked. Status includes orientation and position.
    Added SensorSampleTime to ovrLayerEyeFov, which specifies when the render pose was calculated. This is useful for measuring application tracking latency.
    Added ovr_GetTrackingCaps to get the tracking capabilities of the device.
    Usage of ovr_ConfigureTracking is no longer needed unless you want to disable tracking features. By default, ovr_Create enables the full tracking capabilities supported by any given device.
    Added ovrLayerHudMode, which enables the headset user to see information about a layer.
    Added ovrControllerType_None and ovrControllerType_XBox to ovrControllerType.
    The Oculus Debug Tool was added to simplify troubleshooting. For more information see Oculus Debug Tool.
    Runtime Changes
    Changes include:
    If you have an NVIDIA GPU, make sure to upgrade to the 358.70 driver or later. To get the driver, go to https://developer.nvidia.com/gameworks-vr-driver-support .
    If you have an AMD GPU, we recommend the Catalyst 15.10 Beta or later. To get the driver, go to http://support.amd.com/en-us/kb-articles/Pages/latest-catalyst-windows-beta.aspx .
    API Changes
    This release represents a major revision of the API. Changes to the API include:
    Applications no longer need to call ovr_ConfigureTracking. ovr_Create automatically enables the full tracking capabilities supported by any given device.
    Replaced ovr_GetFrameTiming with ovr_GetPredictedDisplayTime.
    Added latencyMarker to ovrTrackingState. When set to ovrTrue, this indicates that it will be used in the rendering loop and will be used to calculate latency.
    To emphasize the session model, renamed ovrHmd to ovrSession and hmd to session.
    ovrLayerType_QuadInWorld and ovrLayerType_QuadHeadLocked were renamed to ovrLayerType_Quad and are now differentiated by the ovrLayerFlag_HeadLocked flag.
    Added ovrMaxLayerCount, which sets the maximum number of layers to 32.
    Removed ovrInit_ServerOptional. If you use this to detect whether the OVRService is available, periodically call ovr_Initialize or poll ovr_Detect instead.
    Removed ovrTrackingCap_Idle from ovrTrackingCaps.
    Known Issues
    The following are known issues:
    The Oculus service might crash when gathering Diagnostic Logs from the Oculus Config Util. If this happens, the service automatically restarts and the logs will not be lost.
  2. Damit hätte ich diesen Monat, nicht mehr gerechnet. :eek:
  3. Da hat wohl keiner mit gerechnet...
  4. Welch Überraschung, aber an Dezember für 1.0 glaub ich trotzdem nicht. ^^
    Liest sich jetzt nicht sooo spannend. Wichtige Änderungen, die eher Entwickler betreffen und jetzt nicht so viel den Nutzern bringen.
