für Rift Käufer sehr intereesant, es gibt nen Spacer für lau Free spacer for your Oculus Rift adapter and new RABS lens technology with minimal distortions 8 Kommentare "" style="border: 0px; font-style: inherit; font-variant: inherit; font-weight: inherit; font-stretch: inherit; line-height: inherit; font-family: inherit; vertical-align: baseline;"> "" style="border: 0px; font-style: inherit; font-variant: inherit; font-weight: inherit; font-stretch: inherit; line-height: inherit; font-family: inherit; vertical-align: baseline;"> 4 Personen gefällt das When we developed the Oculus Rift VR Lens Lab adapter we had access to three Oculus Rift headsets and the adapter worked fine in all of them. After we shipped the Kickstarter orders some people had problems with their adapters that became a bit loose and didnt stay in place well enough. We tried the adapters on more Oculus Rift once they became available and Oculus caught up with shipping orders and there are minimal differences in Oculus Rift sizing that do make a difference. So the same adapter that works perfectly fine in one Oculus Rift might sit a bit loose in another one. In the last weeks we worked on a solution for this and we are happy to send out free spacers to everyone who experienced this kind of problem. All new orders will ship with these spacers too. You simply clip them into your existing adapter and put the adapter in like you used to do. Watch the short video below on how this works and head over here if you experience this problem and want to get a spacer. If you experience any problems with the fit of your Oculus Rift lens adapter you can head over here to fill out the form and we send you a spacer for free. New RABS lens technology The huge majority of people were really happy with their lenses but a few people had problems with barrel distortion and getting used to it. Some people also asked why we flipped the lenses in our adapters. The reason is to avoid the lenses to touch and possibly damage your VR headset lenses and also sit as close to the headset lenses as possible for maximum FOV and clarity. There is more to that and we explain this in the video below and also introduce our new RABS lens technology. While not necessary for most people we are happy to offer our new premium RABS lenses that are based on the aspherical freeform technology that minimizes any kind of distortions. We offer these new lenses on our website now as an optional upgrade if you order a new adapter. If you only want the RABS lenses to use in your current adapter you can fill out the custom request form here and we send you a price for the lenses only.
Hallo Erstmal! Ich würde mir zu meiner Rift auch gerne zwei Paar Linsen bestellen, eins mit Sehhilfe für mich und eins ohne Sehhilfe für die Freundin oder Besuch. Würde das Blueguard Coating für meine Linsen was bringen oder ist das nur wieder so ein leeres Merketingversprechen? Da ich ja sowieso schon den ganzen Tag auf der Arbeit in den Monitor klotze würde mich das schon Interessieren ob man damit seine Augen etwas schonen kann, sofern dadurch die Bildqualität nicht leidet. Gruß Asder
hiho, willkommen im Forum.. für die rift ist die linsenbefestigung grenzwertig... wie du auch hier in diesen Thread lesen kannst, die wurde zwar gerade mit einen Gummi nachgebessert aber ob das was bringt.. wirst du wohl erst lesen wenn das hier jemand ausprobiert hat. Ich persönlich finde das blue coating gut in meiner Vive. Das bricht ein wenig das Licht von den Godrays.
Über das Blueguard Coating werden bestimmt selbst "Experten" unterschiedliche Meinungen haben. Zumindest kann man wohl davon ausgehen das es keine Nachteile bringt, außer beim Preis. Wenn man keine Sehhilfe braucht, würde ich auch auf die Lenses verzichten (ist aber nur meine Meinung). Allerdings die Sehstärken-Lenses finde ich sehr lohnenswert, wenn man eine Sehhilfe braucht. Mich würde interessieren ob die neue Befestigung besser geworden ist. Ansonsten einfach den 3D-gedruckten Halter (siehe oben) verwenden. Der passt perfekt, alles hält und stört nicht. Den Anhang 1192 betrachten
Also ist or_mount64.stl die richtige Datei für den 3D Druck und die VR Lens Gläser passen perfekt rein? Vielen Dank!
So, meine RABS-Linsen sind unterwegs. Aktuell sind sie in Singapore. Wie lange dauert es dann ca. bis Germany?
Ja, absolut korrekt. Habe sie nun seit dem 10.August fast täglich in Benutzung. Passt und nichts wackelt.
Ich war gestern bei einem 3D Druck Laden und sie meinten, dass das Objekt an einigen Stellen zu dünn ist für den Druck. Oben sehr Ihr die Markierungen, wo das Objekt laut deren Programm zu dünn ist für den Lasersynter (die Stellen würden abbrechen/die Maschine würde das Objekt gar nicht erst akzeptieren). @GeneralDiDi Auf Deinem Foto sind diese auch drauf - gab es bei Trinckle keine Probleme beim Bestellen? VG Udo
Ja, diese markierten Teile sollten unbedingt dran bleiben. Bei Trinckle wird beim upload ein Fehler gefunden, den man dann aber über die Reparatur korrigieren kann. Genauso hatte ich das auch gemacht. Als Material dann Kunstoff-Sintern (flexibel) wählen und als Farbe schwarz (weil es am wenigsten Licht reflektiert) Die Größenangabe ist natürlich in mm.
